JohnA
- Oct 25, 1999
As I posted in my "Maelstrom finally started" post, I am facing some obstacles screwing into the MDF panel for my Maelstrom subwoofer. I don't have any clamps to build the box and my first attempt on screwing and glueing some internal braces ended in near disaster with the MDF splitting.
In the end, I switched from wood screws to sheetrock screws and used a much larger pilot hole than I thought should be used.
What exactly is everyone using for screws? What type and size screw are you using? What size pilot hole?
Thanks for your response.
-JohnA
-JohnA
