GabeT
Grip
- Aug 2, 2002
Anybody have any experience with these little guys? They look good and for $60 for a pair I figured i couldnt go wrong! Is the Xmax specified (16 mm) Linear or is it Bullsh*t? And how do they sound? Any deep bass?
Heres the specs:
•Power capacity: 120W/240W RMS/peak •Frequency response: 20Hz~1KHz •Impedance: 4ohm •Voice coil diameter: 2" •Magnet weight: 47 oz. •Sensitivity: 87dB W/M •Fs: 24.7Hz •Re: 3.4ohm •Le: 2.49mH •Qms: 12.64 •Qes: 0.19 •Qts: 0.18 •Vas: 39.4 liters •Mms: 64.2g •Xmax: 16mm •Magnet gap height: 8mm •BL: 13.46 •Piston diameter: 163mm
Heres the specs:
