raymond caputo
- Apr 16, 2003
its been two month now since i have my mc-8...i am a little confused as to where i should properly set my crossover points..i have set it up according to lexicons specs for bass enhance: 40 main,120 center, large or full sides,40 rear and 40 sub....i'm concerned because my side speakers lowest range is 65hz and my rears 55hz...i have snell xa90's front, xa55 center...psb's for sides and rear....i might also add that the snells have a built in sub...so i am unsure if i should set a crossover point or set it to none....there is also reference to speakers set to large or small, however correct me if i'm wrong, but the mc-8 doesn't have a setting for large or small...right now i have all speakers set to 10hz higher then the lowest point...some suggestions would be apppreciated....
