MB Quart sub, PWE 352. How do the specs look?
Discussion in 'Home Theater Projects' started by jeff lam, Jun 10, 2005.
  1. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I guess these are suposed to be very expensive drivers but are on clearance right now $119. What do you guys know about this MB Quart Sub?
    Impedance 2 ohms
    Cone Material TreatedPaper/Poly dustcap
    Surround Material Santoprene
    Sealed Box Volume (cubic feet) 1.5
    Ported Box Volume (cubic feet) N/A
    Port diameter (inches) N/A
    Port length (inches) N/A
    Free-Air No
    Dual Voice Coil Yes
    Sensitivity 90dB
    Frequency Response 16 - 0.3k Hz
    RMS Power Range (Watts) 50-800
    Peak Power Handling (Watts) ---
    Top Mount Depth (inches) 7 3/8
    Bottom Mount Depth (inches) N/A
    Cutout Diameter or Length (inches) 13 13/16
    Vas (liters) 90.1
    Fs (Hz) 27
    Qts 0.59
    Xmax (millimeters) ---
    Parts Warranty 3 Years
    Labor Warranty 3 Years
    xmax isnt specified. Specs dont look great compared to some other subs but for $120 and i also need a smaller box sub.
  2. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
  3. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Thats what i figured. Whats a good driver to use in a smaller size box with low tuning that doesnt take a lot of power to drive?
    12" should be OK, my spl requirement isnt high. Maybe 100-110 max.
    oh... medium size room with openings. Maybe 500 ft^2 + open rooms.
    I also thought about IB design but dont know that much about it. Could be a possibility.
  4. ThomasW
    Nov 6, 1999
    2,282
    There's no such thing, that would defy the laws of physics.
    "Hoffman's Iron law", you can choose and control any 2 of the 3 following performance parameters, the 3rd one you can't control.
    1)Fs
    2)box size
    3)efficiency
  5. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I have enough power for most drivers, but Im talking about a driver that doesnt require 1000-2000 Watts. I can give it 450W. Right now I have a tempest in a 175 liter tube and its more than enough for me, however I would love to get similar results from 1/2 the size if possible.
  6. ThomasW
    Nov 6, 1999
    2,282
    Buy a second Tempest make a clamshell Isobaric design = same performance and 1/2 the box size.
  7. jeff lam
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    thats an idea I guess but I'm afraid I dont know much about this design. Do you have any links with info on an Isobaric design?
