Max screen size for a 20x13 media room (1 Viewer)
frisco
Andrew
What would be the max (best) screen size for a 20 (long) x 13 (width) media room? What's the typical size for a media room? Thanks.
Robert_J
Mississippi
Max and best are 2 separate things. It depends on the type of display also. Projector/screen or is this a flat TV like a LCD or plasma? Source(s)? HD or SD? Seating distance from the screen?
For example, I have about a 16x24 room and I use a 103", 16x9 DIY screen with a Panasonic AE900U projector. My eyes are approximately 12 feet from the screen. I use a combination of DVD and HD sources with very little standard definition TV watching.
-Robert
Jim Mcc
Oconomowoc, WI.
Jim
Room size doesn't matter. Screen size is based on your seating distance from screen, and resolution of your display.
frisco
Andrew
Thank you for the replies. I am thinking about project/screen. The projector resolution, I am not sure. I have about 8 thousand dollars budget for the project and speakers, so I suppose I can get a decent one. The viewing distance, I don't want to place the sofa against the back wall, so I am thinking maybe 16-18 feet (the room is 20 feet long) away from the screen.
In this setup, is 110'' screen too big? Thanks again!
Jim Mcc
Oconomowoc, WI.
Jim
Believe it or not, a 110" diagonal screen is a little too small(assuming you get either a 720p or 1080p projector). I'd get about a 120" diagonal screen. Make sure the projector is bright enough for your screen size.
Bob McElfresh
I have always found this viewing distance calculator to be a good source:
Viewing Distance Calculator
Plug in the numbers, then play with the screen size to get the distance for the THX suggestion of a 26 degree viewing angle.
Try to get the primary/front seat to have this angle so people in the rearward seats have a smaller angle to avoid eye-strain.
JeremyErwin
That calculator suggests a 26 degree minimum, and a 36 degree maximum. In other words, 26 degrees for the rear, 30 or so for the front.
Kevin Stewart
Texas
Kevin Stewart
My room is 12.5' X 20'. My seating is 13.5' and 19'. I have a 126" (16:9) screen and wouldn't go any smaller.
pankarty
Grip
pankarty
thanks ............
thanks for u ........................................
acinstallation921
