Math help.. Algebra and Geometry...
Discussion in 'After Hours Lounge (Off Topic)' started by Andrew S, Dec 13, 2003.
  1. Andrew S
    Andrew S Stunt Coordinator
    Sep 30, 2001
    214
    I'm taking an Algebra and Geometry class through correspondance and I'm having some troubles with a couple questions...
    52. If vector a and vector b are unit vectors and the angle (theta) between them is 120 degrees, calculate
    (5a-b)*(a+b)
    The second question is pretty much the same setup...
    I know that I have to use the equation:
    cos theta = a * b / |a||b|
    I just get lost interpretting the significance of a and b being unit vectors?
    Any tips would be greatly appreciated
    Andrew
  2. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    [​IMG] My head hurts. I go sleepy now.
  3. Andrew S
    Sep 30, 2001
    214
    lol.. turns out unit vector means I just make it equal 1. duh...
  4. Dome Vongvises
    Dome Vongvises Lead Actor
    May 13, 2001
    8,172
    Vectors, as you'll learn in physics, are quantities that possess both magnitude and direction.
  5. Andrew Testa
    Andrew Testa Second Unit
    Mar 22, 2002
    263
    Andrew,
    You pretty much got it. a unit vector is a vector with a length (magnitude) of 1, regardless of its direction. So if the question was asking you to use the vector length in the calculation, just use 1, and the angle was a red herring.
    Andy
  6. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    Well something's funky.
    If cos theta = a * b / |a||b|
    then cos(theta)=1*1/1*1=1
    but cos(120)=.8142
    so it would appear that the a & b don't represent length of the vector, since it's certainly possible to have two unit vectors with an angle of 120 degrees. I don't know what a & b are supposed to be in that formula for the cos (theta), but it isn't length.
  7. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
  8. Will Pomeroy
    Will Pomeroy Stunt Coordinator
    Feb 9, 2002
    144
  9. Joseph Howard
    Joseph Howard Stunt Coordinator
    Sep 10, 1997
    227
    Careful about helping. There are many final exams
    occuring right now. Both in traditional classes and
    via correspondance courses.
    Hate to cause a problem, but be careful.
    Dr. Joe
