Where do you get modeling clay to add mass to a PR? Is there any method for secure attachment? Are there better substances (besides clay) to use? Thanks!
Modeling clay works great because it's sticky enough to stay in place all on it's own.. Just make sure to pack it against the edges so it sticks.. It works great in combination with fender washers if you need a lot of mass as it will hold them in place well.. no worries about them falling out or rattling around.. Plus you can always dig it all out fairly easily if you ever want to change your tuning..
I think modeling clay can be found at your local hobby/craft type stores.. Fender washers at home depot or anywhere that sells washers/hardware..
