Jack Briggs
- Jun 3, 1999
Is the store from which you purchased the unit an authorized Marantz dealer? Was the original seal on the shipping carton broken or altered? Was there any cosmetic damage to the unit (scratches on the faceplate or the chassis? etc.)?
Are you connecting the speakers correctly? Have you run the test tones (with an SPL meter on hand to check the results)? How thick is the speaker wire you're using?
