Jimmie
- Jun 15, 2000
Selling this like new receiver for $700.00 plus shipping from zip 29732. Thanks for looking.
Jimmie
Details:
The Marantz SR7300ose, a supercharged version of the Marantz SR7300, is designed for exceptional high-end home theater performance that incorporates DTS® ES-discrete 6.1-channel decoding for enhanced surround sound realism. The additional back surround channel decoded from DTS-6.1 encoded discs provides a more realistic surround sound environment by allowing smoother, 360-degree sound effects. For enhanced performance, the SR7300ose incorporates a copper plated chassis with double bottom plate, upgraded power supply, better shielding and wiring and gold plated input and output jacks. The Marantz SR7300ose also offers a selection of other useful surround modes, including Dolby Digital® EX, DTS® 5.1 decoding. Dolby Pro Logic II® (Music and Movie) decoding, an HDCD decoder, as well as SRS Circle Surround® II (6.1). The SR7300ose’s advanced DSP circuitry utilizes 24-bit, 192 kHz audio decoding and a leading edge Crystal® DSP chip for superlative fidelty and resolution. The SR7300ose is software upgradeable and easily controlled via a RS232C terminal and includes a programmable learning remote control.
Features
110 Watts x 6 (Into 8 Ohms)
All Discrete Amplifier Stages
192 kHz/24-bit D/A Converters For All Channels
Dolby Digital EX 6.1/5.1, DTS 6.1/5.1
DTS 96/24
Dolby Pro Logic II (Movie, Music)
6 Channel Stereo Mode
HDCD Decoder
Multi-room, Multi-source Capability
Speaker A/B Switching
Gold Plated Inputs/Outputs
Copper Plated Chassis With Double Bottom Plate
Several modifications to the Power Supply, Signal Path, Output Devices, Preamp Stage as well as improved internal Wiring and Shielding
Specifications
Software Upgradable (RS-232)
THX
DTS ES 6.1 Discrete/5.1/Neo:6 + DTS 96/24
Dolby Digital EX®
Dolby Pro Logic II
Circle Surround SRS CS® 6.1
HDCD Decoder
Current Feedback Topology
Discrete Amplification
Power Transformer EI (Upgraded)
D/A Conversion 192 kHz/24-bit (Hand Selected)
Digital Surround Processing Crystal® (Hand Selected)
Video Off
Source Direct
Chassis AllCopper w/ Double Bottom Plate
Customized Components
Shielding Extensive Shielding in all Critical Areas
Composite In - 5 (gold plated)
Composite Out - 3 (gold plated)
S- Video In - 5 (gold plated)
S- Video Out - 3 (gold plated)
Component In - 2 (gold plated)
Component Out - 1 (gold plated)
Analog In - 8 (gold plated)
Analog Out - 4 (gold plated)
Digital In - 7 Total
Digital Optical In - 4 (3 assignable)
Digital Optical Out - 1
Digital Coaxial In - 3 (assignable)
Digital Coaxial Out - 1
Pre- Amplifier Out - 7.1 Channels (gold plated)
Main Amplifier In
Multi-Channel In - 8 Channels (gold plated)
Multi-Room Audio Out - L/R Pre-out (fixed or variable)
Multi-Room Video Out - 1 (CVBS)
RS232C
DC Triggers - 2 (assignable)
Speaker Terminal A/B + C, Sl, Sr, Sb
Multi-Room Speaker Terminal
D-Bus RMC Out
Multi-Room RMC
External IR Yes - thru RC-5
AC Outlets Yes, (1 switched/1 unswitched)
Front Inputs L/R, CVBS, S, Opt. Digital
Headphone Out
Power Output (8 Ohm) 110 W x 6, (
Jimmie
Details:
Features
DTS 96/24
HDCD Decoder
Specifications
THX
Dolby Digital EX®
Dolby Pro Logic II
HDCD Decoder
Video Off
Source Direct
Main Amplifier In
RS232C
D-Bus RMC Out
Multi-Room RMC
Headphone Out
