Marantz SR6300 question
Discussion in 'Archived Threads 2001-2004' started by Peter_ OB, Mar 25, 2003.
  1. Peter_ OB
    Peter_ OB Auditioning
    Mar 13, 2003
    5
    I hooked up my new Marantz SR6300 today and can't get the On Screen Display to work. I have an S-video cable from the the monitor out on the receiver to the TV and I also hooked up a composite cable with the same connections and it still doesn't work. Any suggestions? Also, the volume is very low. I have barely normal sound at -25db. What could I have done wrong?
    thanks
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    If you have the s-video hooked in the back of the Tv make sure you have your input switched to that input (2 or 3)..
    so that you can see your OSD.
  3. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Forget about the composite connection and don't forget to press AMP on the remote before pressing OSD.
  4. Peter_ OB
    Mar 13, 2003
    5
    Thanks Chad & Chris - that worked. The manual didn't give that level of detail. My problem was that I didn't change the input to #1,
    A couple of other questions:
    I have tried to set the TV Auto on/off but can't get it to work. Any suggestions?
    The volume when playing a DVD is low (-10db)compared to TV listening (-40db) Any suspicions why? I am new to this and appreciate the help
  5. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Sorry, I don't use that feature, so I don't know what you can do. Not sure about the level difference either.
