Marantz SR6200 LFE setting?
Discussion in 'AV Receivers' started by Chris PC, Mar 22, 2004.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    I have my SR 6200 LFE set at 00 dB. The other options are OFF or -10 dB. Any idea why you would set it to -10 dB or OFF? If you had it to OFF, what does that do? I mean, surely you will still hear the sound effects, right? Mixed down or something? I guess I don't really understand LFE channel too well. Thanx for any feedback [​IMG]
  2. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Anyone with any Marantz receiver have comments about the LFE settings?
  3. ChrisDixon
    ChrisDixon Second Unit
    Nov 20, 2001
    306
    It's always best to use the unaltered settings for things like that. My guess is that turning down the LFE is a "feature" that is meant for late night or more quiet viewing times.
    Chris
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I think the -10dB setting is a compensation for some specific setting on certain sources. If you turn it off, there is no LFE at all. I tried it in all three, and left it on 0dB. There is a setting called night mode, which is completely independent of this setting.
  5. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Right. I figured 00 dB was correct. I just wondered why the -00 dB setting.
    Why would you use LFE=OFF? I'm not sure why you'd do that unless you've no subwoofer. But wouldn't you want the LFE to be mixed with the other speakers. I guess I don't understand what LFE=OFF would actually do inside the receiver.
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Hmmmm, I don't know what exactly it's purpose is either, just that it didn't sound right.
  7. Tom Sullivan
    Tom Sullivan Agent
    May 16, 2001
    41
    Zero means flat, minus DB's is for lowering the output.
    0 is best, I set my SR8000 to Cinema EQ On also, to keep my ears from ringing. [​IMG]
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I pulled up the manual for the 9300, and it says the -10dB is for DTS music only, and the normal setting is 00dB. There is no explaination for a case when one would want to set it to off.
  9. Tom Sullivan
    Tom Sullivan Agent
    May 16, 2001
    41
    "-10dB is for DTS music only, and the normal setting is 00dB. There is no explaination for a case when one would want to set it to off."
    This makes sense with DTS bass being overly strong.
  10. ericLee
    ericLee Stunt Coordinator
    Oct 15, 2002
    135
    I asked the same Q when i had my 6200. The 00db was said to be correct and the other settings are used to compensate for improperly coded dts or some music dts discs that are encoded that way. This setting wasn't on my 6300 so i think they might have taken it out
  11. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    My 8300 still has it, so it is likely still there, just in a different setup location. I've used the 6300, but I don't remember having to set that, since the default is 00dB
  12. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    It's a thing for DTS. I think the manual explained, but I've long since forgotten, I've left it at 00.
  13. ChrisWiggles
    Aug 19, 2002
    4,791
