marantz sr 8200
Discussion in 'Archived Threads 2001-2004' started by Mike Ward, Jan 20, 2003.
  1. Mike Ward
    Mike Ward Stunt Coordinator
    Dec 8, 2001
    104
    less than 2 months old with every thing that came with in the box With the included RC3200 Programmable touch screen 2-way learning remote, you can run the whole show from the couch. It too has an RS232 input, and 1 MB of Flash memory.
    The 8200 has extensive inputs and outputs. Analog Audio: 8 in/4 out; plus 7 digital inputs of which 6 are assignable. Video: 6 composite inputs/2 outs, 6 S-video inputs/2 out, 2 component video inputs, 1 output; 7.1 channel pre-amp outputs, 7.1 channel inputs, Multi-room outputs, Digital Optical 3 inputs/1 out; Digital Coaxial 3 inputs/1 out. Plus there are 4 front panel audio and video inputs for easy access.
    Features:
    THX Select®, THX Surround EX®, Dolby Digital®, DTS ES® (Discrete 6.1, Matrix 6.1, Neo: 6) Dolby Pro Logic II® (Movie, Music) Circle Surround 5.1®(Movie, Music) 6 x 120 Watts (8 Ohm), Discrete Amplifiers ® High Power Current Feedback Circuitry 192/24 bit Crystal DAC® for all 6 Channels 2 24-bit Digital Surround Processing Chipsets Video Off Mode RS232C Terminal On Screen Set Up Auto Input Signal Detection Station Name Input, 50 Presets Auto Adjust Function for Speaker Distance Adjustable Delay Settings 2 Assignable DC Trigger Outputs RC3200 Programmable Touch-Screen, 2-Way, Learning Remote Control Composite In: 6 (DVD, DSS, TV, VCR1, VCR2/DVD-R, AUX) Composite Out: 2 + 2 (monitor) S-Video In: 6 (DVD, DSS, TV, VCR1, VCR2/DVD-R, AUX) S-Video Out: 2 + 2 (monitor) Component In: 2 (DSS, DVD) Component Out: 1 (monitor) Other Pre-Amplifier Out: 7.1 Channels (F, C, R, S, SB, SW) Multi-Channel In: 7.1 Channels (F, C, R, S, SB, SW) Multi-Room Audio Out: 1 (RCA) Multi-Room Video Out: (Composite) Analog In: 8 (CD, TAPE, CD-R/MD, DVD,DSS, TV, VCR1, VCR/DVD-R) Analog Out: 4 (TAPE, CD-R/MD, VCR1, VCR-2/DVD-R) Digital In: 7 (6 assignable) Digital Optical In: 3 Digital Optical Out: 1 Digital Coaxial In: 3 Digital Optical Out: 1 Pre-Amplifier Out: 7.1 Channels (F,C, R, S, SB, SW) Multi-Channel In: 7.1 Channels (F. C, R, S, SB, SW) Front Inputs 4 (Audio, Composite, S-Video, Optical Digital) Headphone Out Remote Control: RC3200, RS232C Cable Included Dimensions (Inch, W x H x D): 17 5/16 " x 7 1/4 " x 8 7/8" $1150 shipped or B.O
  2. Mike Ward
    Dec 8, 2001
    104
    price drop 1100 shipped
  3. Mike Ward
    Dec 8, 2001
    104
    price drop $1050 shipped
  4. Carl
    Carl Stunt Coordinator
    Feb 13, 1999
    225
    YGPM
  5. Mike Ward
    Dec 8, 2001
    104
    YGPM
  6. Carl
    Feb 13, 1999
    225
    YGPM
  7. Carl
    Feb 13, 1999
    225
    YGPM
  8. Mike Ward
    Dec 8, 2001
    104
    sorry sold
