Marantz SR-7200 Need HELP!!!
Discussion in 'AV Receivers' started by Dave_La, Aug 22, 2003.
  1. Dave_La
    Dave_La Stunt Coordinator
    Apr 28, 2003
    55
    Hey guys, I was trying to hook up the SR-7200. No sound from sub. Sub is activated through receiver's OSD and DVD player's OSD. Receiver front panel's "SW" icon does light up but doesn't give me anything. It's hooked up using a regular RCA digital coax from the receiver's pre-out subwoofer to the paradigm's pdr-12 LFE input. Clueless to what is going on. Could my Marantz be a defect, I did buy it refurbished from accessory4less.com. Anyone experiencing the same problem with this receiver. Any inputs appreciated. Thanks.
    David
  2. Steve Marsh
    Steve Marsh Stunt Coordinator
    Aug 22, 2002
    152
    First check your RCA Cable. Either ring this one out or try a known good one.
    Second try a diff source to your sub to confirm the sub is good.
    FWIW.
    Those 7200s had a lot of problems but I've never heard that one.
  3. JohnOwens
    JohnOwens Agent
    Mar 2, 2003
    25
    Make sure the "direct" mode in not engaged. You will see the word direct in red on the display if it is. This setting bypasses a sub and crossover settings, just running your mains as large.
  4. Dave_La
    Apr 28, 2003
    55
    THanks guys. got it to work. My speakers were set to large. That's why.
