1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Marantz? Rotel?...advice needed please
Discussion in 'AV Receivers' started by Dan K, Jan 7, 2005.
  1. Dan K
    Dan K Auditioning
    Jul 31, 2004
    10
    hey everyone,
    i'm putting together a system with a fujitsu plasma, artison portrait speakers, sonance in-ceiling rears and a b&w asw675 sub.
    i'm considering one of the following receivers:
    marantz sr5500 ($650)
    marantz sr7500 ($1,100)
    rotel rsx-1056 ($1,300)
    the room is a great room with an open kitchen right off it. it's about 15' X 30' with 8 1/2' ceilings.
    i will be listening to music as well (a big reason i'm looking at marantz and rotel) but i'm not expecting the sound that my old b&w two channel system used to give. the artison's are a compromise since we are putting the tv above a fireplace. but i would still like it to sound decent.
    is it worth going for the 7500 over the 5500 for an extra $450?
    does the rotel sound $200 better than the 7500?
    thanks a lot for any input.
    dan
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Where are you located? I can get the 7500 for less than that if you are local. The 7500 has auto-EQ, which the 5500 does not, and it has a worthwhile jump in power. The auto-EQ would probably make it worth it over the Rotel as well, but IMO, the Rotel is going to sound better. $200 better is hard to say. What are the specs for the Artisans?
    You might want to reconsider the sub. B&Ws subs are decent, but there are better value subs with similar or better performance available through internet direct companies, as you will come to see on this forum.
  3. Dan K
    Dan K Auditioning
    Jul 31, 2004
    10
    thanks for the reply.
    here are the specs on the artison speakers:
    sensitivity-- 89db @2.83 volts, 1 meter
    nominal impedance--6 ohms
    it sounds like they present an average load. (you can see them at artisonusa.com if you're curious.) i auditioned them and thought they sounded great and solved my speaker/fireplace problem with the center channel.
    the prices i put up are manufacturer listings. i do plan on purchasing my equipment through a dealer here however. they have already done the prewire for me.
    thanks again.
    dan
