Marantz MM9000....is it worth the purchase?
Discussion in 'AV Receivers' started by steve lucchetti, Feb 9, 2004.
  1. steve lucchetti
    Sep 9, 2003
    31
    I am looking for a multi-channel H/T amp. to drive my Rocket speakers. I will be using a Denon 3803. I have read info from others on the Marantz MM9000, but I can't get myself to believe that this amp is any good mainly due to its cheap cost?
    Why is this amp so cheap as compared to other with similar power etc. Is it worth purchasing? I really don't need anything more than 150 wpc, but my Rockets would love the 200 watt power!
    I've looked on audiogon and need something in the $800-$900 price range.
    Any input would be great.
  2. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    I remember reading a great review on it when it came out way back when in Home Theater Magazine.
    It wasn't the end all, but it did well.
    I have no idea why it is not more known and used. I would try it especially if you are gonna get it here...
    http://accessories4less.com/Amazing/...FSCat=++++++34
    Also check out Outlaw.
    And if you could just stretch it to 1000 or even 1200 that will give you a bit more choices.
    If you do decide on the Marantz let us or at least me know I was always way curious about that piece.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    You can get teh MM9000 for $699 BRAND NEW with free shipping from www.ac4l.com. It is cheap because it has been discontinued. THX Ultra cert means it can hold it's own.
  4. Ray_C
    Ray_C Stunt Coordinator
    Jan 6, 2004
    106
    I got one a month ago with that same deal. It arrived in three days. It works fine and is a definite upgrade over just about any receiver's power section (using mine with a Denon AVR2803 as pre/pro). It's easy to set up and the auto on/off trigger works perfectly. Neutral sounding and runs quite cool with efficient speakers, with gobs of power to spare. All for $699 shipped. What's there not to like?
  5. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    314
    14
    Steve, we are looking at the exact same thing. I have just started looking at my options and have come across the MM9000. I was really looking for a good two channel amp.. Outlaw M200, Adcom 5400/5500, ATI 1502 or Parasound 1000/1500 were some of the ones I was considering. I have JBL 312 Studio Towers up front and my receiver, V444ES, seems to start to run out of power at very high levels.
    The MM9000 seems to have a wonderful price for 5 channels (THX Ultra)of 150wpc and I've seen nothing but good reviews. My question is also, what's up with this and how come it's not discussed more in here? I'd love to hear more about this amp or others that I was looking at compared to this guy.
  6. Ray_C
    Jan 6, 2004
    106
    It seems that Marantz's venture into separates wasn't as widely acknowledged as other affordable companies like Adcom, NAD, et al. I'm still looking to get a couple of those monoblocks. Denon, Yamaha, Sony, and HK have also put out separate amps over the years, but you don't hear much about them either. I think that certain brands are associated with different types of units. Probably wouldn't be worth it for these bigger manufacturers to go into separates when they don't get half the attention of their combined receivers. A Marantz might not have the bragging rights of some B&K or McIntosh amps, but it seems to be a quality unit nonetheless.
  7. Felix_H
    Felix_H Stunt Coordinator
    Jan 22, 2000
    66
    The reason why the MM9000 is not discussed as much is because they are somewhat old now. If I am correct, I think all the channels may share the same power supply as compared to higher end competitors
    Also, the MA500 and MA700 Monoblocks seem to have been more preferred.
    Besides that, they are probably a great bang for the buck amplifier...especially for people looking to add power or starting to get into separates.
    Really cant beat 5x150w, THX certified for under $700us!
  8. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    I'd say timing, this came out at the infancy of DVD when the players was in the $1000+ range and therefore those who might get into separates now would maybe not be able to afford this as well. It also didn't help that Outlaw came out with a better amp shortly there after which imo was better at the same price point.
    This amps a bargain for it's price and would definitely help anyone who wants to upgrade their theater for a minimal price (compared to say a new AVR or speaker set).
  9. terence
    terence Supporting Actor
    Nov 8, 2002
    985
    I just placed an order for the MARANTZ MM9000, and it should show up on Friday (I hope) for me to play with all weekend. I will be mating it with a Sony STR-DA4ES that will handle Pre/Pro duties for now on. I will post my findings after i run my torture test over the weekend. The 4ES has done a wonderful job since Sept, 2002, but now i'm ready to slide into seperates. My $$$$ is right so why not?!
    I don't know if you guys seen this yet, but check it out.
    http://www.marantz.com/pdfs/u_mm9000.pdf
  10. George Caronan
    George Caronan Stunt Coordinator
    Nov 25, 2003
    215
    Hello. I bought mine from the same place a week ago. I have it mated to a Denon AVR5800 in a 5.1 setup bi-amping four floorstanders. The Marantz is powering the highs with the Denon powering the lows. So far, the combination has been excellent. The Marantz is rated at 150 wpc but I read that it is really 170 wpc so the original specs are conservative. All channels do share the same power supply but it is a huge one at that. The build is quite sturdy [Japanese made] with THX Ultra cert on it. Sound wise, it exhibits a warm, musical quality. Not too forward or bright in a sense. One minor quibble on it are the binding posts originally come in with these plastic plugs in the center. Apparently these things are there for some sort of safety regulations. In order to use banana plugs, one has to drill a small hole in the center and pull them out. All in all, I felt it was a worthy investment. Cheers!
  11. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    All of my Marantz gear has come with the banana covers. I was able to easily pop them out with a pocket knife.
  12. Marvin
    Marvin Screenwriter
    Apr 9, 1999
    1,480
    41
    Marvin
    By any chance, has anyone ever compared this amp to the Parasound 855A? That amp is only 85W so should I assume the Marantz is a lot better? Or is there something about a Parasound amp that would make them close?
    I'm currently using the 855A for my front and center speakers (NHT Super 2 and 1, respectively, whose sensitivty is a mere 86db). My receiver has only 3 pre-outs so I'm using it for my 2 rear speakers. Just looking for an excuse to upgrade, I guess. I estimate I use my system for about 75% music to 25% HT.
  13. Ray_C
    Jan 6, 2004
    106
    More wattage isn't necessarily a guage of quality. For most home theater environments, 85 honest watts is plenty of power, especially if you have efficient speakers (89+ dB sensitivity). Where the extra watts come into play are as you turn up really loud and want as much clean headroom as possible, or when there are quick bursts of high volume sound (like the depth charges in "U-571"), or when there are great demands of bass frequencies. If your speakers are of lower sensitivity, or are 4 ohm impedance, then it definitely helps to have more power in order to reach near-reference levels with clean power. The NHT's aren't as efficient as other comparable speakers, but your Parasound should still handle everything quite well. I just recently made the move to separates, so for my price range, the Marantz fit in very nicely. Even if you get a dedicated HT preamp somewhere down the line, the Parasound should provide plenty of power unless you like to listen at really loud levels.
  14. Truong
    Truong Auditioning
    Nov 29, 2001
    4
    I was also looking at this amp and some others. Some
    questions on the specs that maybe someone knows?
    1. Whats the 4ohm rating? All channels driven.
    2. Is the power supply 400W?
    I also looked at outlaw and used sherwood.
    Outlaw 7100: 7x100(8ohm), 7x165 (4ohm), 51 lbs, $900
    Sherwood AM9080: 5x120(8ohm), ?(4ohm), 60 lbs, $400 used
    Do you think this ones a better buy? I look at
    the weight since that's indicative of the power
    supply.
  15. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I heard may great things on the Sherwood. I own a Parasound and well I have no complaints. If I were you I would save the $500 and put it into something else in your system....dvd player or whatever.
  16. George Caronan
    Nov 25, 2003
    215
    Marvin,
    The Parasound that you own is a great little amp. I use to own their amps and had no problems with them. Great performers. Nice neutral, laid back amps. I had two Parasound HCA-1201As before getting the Marantz MM9000. They were rated at 125 watts per channel at 8 ohms. I was loathe to give them up but space considerations and other things made me decide. Both had clean detail, great imaging but the Marantz had more punch and more musicality IMO plus it is able to keep up with the Denon AVR5800's amps which I'm using to power the low end on all four floorstanders in a 5.1 set-up. Both are THX Ultra Certified with gain controls for each channel. I had nothing but good times with the Parasounds.
  17. steve lucchetti
    Sep 9, 2003
    31
    I just went ahead and ordered the MM9000. Accessories4Less has 10% off this month so I picked it up for $670.45 shipping included. Had could I go wrong for that price???
  18. George Caronan
    Nov 25, 2003
    215
    Steve,
    Good for you. I should've waited and saved $28.55! For $699, I can't complain either. The bit about the center plugs have been addressed in this thread but if you want to use an auto on trigger get an RCA adaptor that accepts a 1/8" plug. The trigger on with the MM9000 is video sensing as well but how often does one use video to activate an amp anyway. Only one I've seen with this unique feature. Post a thread here once you get it and let us know how it turns out for you.
  19. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    It is listed as 6 Ohm minumum, but so is my 8300 and I am running two 4 Ohm mains (91.5 dB efficient and relatively low current draw though) and it only gets a tiny bit hotter. Since the 9000 has a larger power supply, I'd expect it will be fine with a few 4 Ohm speakers hooked to it, but it might not like 4 Ohms all the way around.
  20. terence
    Nov 8, 2002
    985
    Well the MM9000 showed up yesterday and all is well so far eccept.
    I'm having problem getting the 12V trigger on the 4ES to turn the MM9000 on & put it in standby mode. I bought a stereo mini 1/8 plug and a stereo to mono (RCA end) and nothing. Then i used a mono mini 1/8 plug w/ the same adapter nothing.[​IMG] Okay now i went w/ a video cable out of the monitor out of the 4ES and sill NOTHING![​IMG] Because my RPTV dose not have a video out.........have no idea why not.
    So now what fellas?![​IMG] [​IMG]
