I'm having trouble with accessing the OSD using the remote or on the unit. The video switching portion does work with S-Video or Composite on other items like LD, VCR, so there must be some trick that I can't figure out.
I have an AV600. I'll try to dig up the manual tonight and maybe I can fax portions of it to you if you have a fax number.
The OSD doesn't work if you're connected to the TV with Svideo, only if you connect via composite, as I recall.
You can't switch different types of sources. So, if you run a composite to the TV, you can only switch composite. If you run Svideo, you can only switch Svideo.
So, if you have Svideo from say a DVD into the AV600, and a composite from a VCR into the AV600, and then an Svideo from the AV600 to the TV, the VCR won't work.
The video switcher can't convert a composite signal into Svideo and vise versa, I don't think any video switcher can, but I know the AV600 can't.
I'll come back here tomorrow if I can find my manual.
...Jim
Please fax the pertanent parts of the manual to me at 708-447-7875.
I do use an s-video switcher and I think that may be part of the problem too.
It sure is nice to have access for this type of information via the HTF! [Edited last by GarryW on October 24, 2001 at 09:55 AM]
