I was wondering if the Marantz SR7000 has enough power for Dynaudio 72 or 82.Was thinking of upgrading to dynaudio or Mirage om7 or om9.Any help would be appreciated.
I would think that you shouldn't have any trouble with the Mirage speakers at 8 ohms and 90db sensitivity. The 4 ohm load Dynaudio's might give you some grief though.
Ricky,
You should visit the Dynaudio website see below.
I drive my Dynaudios (Contour 2.8 towers-not in production anymore) with 200 watts @4 Ohms in a medium room. This is so I have plenty of headroom for really loud passages. They are rated at 86dB sensitivity.
I don't know what your Marantz has for amp power, the 82 are more efficient than the 72.
You would find the following on the website:
Audience 72
Sensitivity (2.83 V/1 m):
86 dB
Recommended Amp. Power:
Small size rooms: >25 watts
Medium size rooms: >65 watts
Large size rooms: >125 watts
IEC Long Term Power Handling:
210 watts
Impedance, Nominal:
4 ohms
Audience 82
87 dB
Medium size rooms: >50 watts
Large size rooms: >100 watts
300 watts
Impedance, Nominal:
4 ohms Link Removed [Edited last by BruceD on October 31, 2001 at 04:12 PM] [Edited last by BruceD on October 31, 2001 at 09:01 PM] [Edited last by BruceD on October 31, 2001 at 09:01 PM]
