AjayRAV
- May 6, 2003
Hello,
I have a Marantz 6200 receiver that I would like to upgrade to the 7500 and have a few questions....
1) Is there a difference in sound quality between the 2 receivers in source direct mode. I primarily listen to music in this mode (85% music, 15%HT) and use DD or DTS for movies (no PL2 or CS).
2) With the 6200, turning off Source Direct affected the sound negatively. Does this also occur with the 7500.
3) Does the 7500 have an auto-eq function? If so how many bands does it look at? Would it also equalize the sub out?
4) How would the 2 channel performance compare with an integrated amp such as the new Marantz 7200 or an older higher quality receiver such as the Sr8200/8300?
My other components are Marantz VC5200 DVD player, Sony - 222ES CD/SACD changer, Ascend speakers and a RAVA sub.
Thanks in advance,
Ajay
Thanks in advance,
Ajay
