Paul Clarke
- Jan 29, 2002
Thinking of pulling the trigger on this one for the bedroom setup. Just like some input, good or bad. TIA.
What about Bass management? Any problems? I know nothing is in the manual but from the user experience, I assume your using speaker level control? I like to use line level but could do the other.
I'm not sure what this means. I am using line level to the sub. You have no adjustable bass x-over, but there are four choices for speaker config - each large or small and with or without sub.
Nobody was ever really able to confirm the low pass x-over or slope, but I believe it is fairly well hidden, obscurely in the manual where it states: "set your speakers to large if they handle bass well below 100Hz" That gives me the impression the x-over is @ 100Hz. MANY people complained about this being too high, but it must be a 6db or 12db/octave slope, because I have absolutely no issues whatsoever.
Basically what I'm saying is, I think Marantz are definitely worth buying. My second choice was a Denon 3802, a much more expensive unit with a few more features and about the same power, but I went with the Marantz because it sounded GREAT.
