Marantz 5200 remote lost codes?
Discussion in 'Archived Threads 2001-2004' started by Greg W L, Jan 15, 2002.
  1. Greg W L
    Greg W L Agent
    Nov 13, 2001
    36
    While I was away the remote for the SR -5200 needed a battery change and since then it has lost it's ability to work with the DVD, TV and VCR. Still works with the receiver. Did we do something wrong? Is this a common occurance. I will re-enter the codes for these items tonight, hope they work. Any ideas why this happened.
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I don't think that remote has memory. When the batteries die, you lose your settings if I am not mistaken. Program one code in, then pull the batteries and see if it is still there. The remote that came with my 6200 was a POS also, so I bought a better one.
  3. Greg W L
    Greg W L Agent
    Nov 13, 2001
    36
    Thanks John, I re-entered the codes and it works fine now. The manual says nothing about the codes not being stored when batteries die or are changed, but then the manual doesn't say much about anything!
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Yeah, not exactly the best manuals...[​IMG]
