Marantz 4001 HDMI Question?? (1 Viewer)
Gerald LaFrance
Earth
Gerald LaFrance
Hi, I have aMarantz 4001 Reciever that has 2 HDMI Inputs and 1 Output it says it is version 1.1 no A/B just 1.1?? I wanted to know will this Pass a 1080p signal from a PS3 or Xbox??
Also what about the Audio will it also pass the audio thru the HDMI??
THNX
Gerald
gene c
Bay area, Ca
Gene
The Marantz SR 4001 is an hdmi 1.1 "repeater" as opposed to a "switcher" or "pass-thru". It will pass 1080P video. As for audio, it will pass the regular DD and DTS and it should pass DVD-A over hdmi but not SACD.
In case you were interested, here is a list of the different versions of hdmi.
Q. What functionality was added to each version of HDMI?
The following provides an overview of major functionality added to each version of HDMI:
HDMI 1.1:
Support for DVD Audio.
HDMI 1.2:
Adds features and capabilities that increase HDMI's appeal for use in both the CE and PC industries. Specifically, the features and modifications for HDMI 1.2 include: Support for One Bit Audio format, such as SuperAudio CD's DSD (Direct Stream Digital), changes to offer better support for current and future PCs with HDMI outputs, including: availability of the widely-used HDMI Type A connector for PC sources and displays with full support for PC video formats, ability for PC sources to use their native RGB color space while retaining the option to support the YCbCr CE color space, requirement for HDMI 1.2 and later displays to support future low-voltage (i.e., AC-coupled) sources, such as those based on PCI Express I/O technology.
HDMI 1.2a:
Consumer Electronic Control (CEC) features and command sets and CEC compliance tests are now fully specified.
Creation of version 1.2a of the HDMI Compliance Test Specification (CTS), which includes a CEC Supplement. HDMI CTS 1.2a has been updated for technical consistency with HDMI Specification 1.2a as well as to the recently released HDMI Specification 1.2.
Significantly, CTS 1.2a contains additional cable and connector testing and Authorized Testing Center (ATC) submission requirements. Specifically, under CTS 1.2a, the Adopter shall submit for testing to the ATC any new HDMI cable whose length exceeds previously tested cables.
Additionally, HDMI Licensing, LLC will maintain a list of approved connectors. For a device to pass CTS 1.2a testing at an ATC, all connectors on such device must appear on the approved connector list. To add a connector to this list, the vendor must submit to the ATC or HDMI Licensing, LLC full and passing testing results.
HDMI 1.3:
Higher speed: HDMI 1.3 increases its single-link bandwidth to 340 MHz (10.2 Gbps) to support the demands of future HD display devices, such as higher resolutions, Deep Color and high frame rates. In addition, built into the HDMI 1.3 specification is the technical foundation that will let future versions of HDMI reach significantly higher speeds.
Deep Color: HDMI 1.3 supports 10-bit, 12-bit and 16-bit (RGB or YCbCr) color depths, up from the 8-bit depths in previous versions of the HDMI specification, for stunning rendering of over one billion colors in unprecedented detail.
Broader color space: HDMI 1.3 adds support for “x.v.Color™” (which is the consumer name describing the IEC 61966-2-4 xvYCC color standard), which removes current color space limitations and enables the display of any color viewable by the human eye.
New mini connector: With small portable devices such as HD camcorders and still cameras demanding seamless connectivity to HDTVs, HDMI 1.3 offers a new, smaller form factor connector option.
Lip Sync: Because consumer electronics devices are using increasingly complex digital signal processing to enhance the clarity and detail of the content, synchronization of video and audio in user devices has become a greater challenge and could potentially require complex end-user adjustments. HDMI 1.3 incorporates automatic audio synching capabilities that allows devices to perform this synchronization automatically with total accuracy.
New HD lossless audio formats: In addition to HDMI’s current ability to support high-bandwidth uncompressed digital audio and all currently-available compressed formats (such as Dolby® Digital and DTS®),
HDMI 1.3a adds additional support for new lossless compressed digital audio formats Dolby TrueHD and DTS-HD Master Audio™.
S205449
