Manually Opening a DVD Changer.
Discussion in 'Archived Threads 2001-2004' started by Chris Ryan, Jan 30, 2003.
  1. Chris Ryan
    Chris Ryan Agent
    Apr 14, 1999
    29
    Hi:
    I have a Kenwood Soverign DV-5900M DVD changer. One of the discs fell over & now it will not open. How do you open it manually?
    Chris
  2. Dan_Jones
    Dan_Jones Stunt Coordinator
    Dec 1, 2001
    120
    Should be some screws to take the casing off, just be careful to not break anything inside [​IMG].
  3. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    You may want to consider taking it to a professional repair facility just in case, if they break it, they'll owe you a new player.
    Depending on where the disc is stuck will depend on the ability to be removed.
  4. Tom Lee
    Tom Lee Agent
    Oct 21, 2002
    32
    I have a Sony 655 DVD 5 disc carousel. I took it apart.. it wasn't a big deal. Just lay it down, the way it supposed to be.. and unscrew certain screws (on the sony anyways) The screws were on the back, and the top cover slid off. took out the CD/DVD, and pop the case back on.. it's happen 1 more time after that.. but not a problem since.
  5. Chris Ryan
    Chris Ryan Agent
    Apr 14, 1999
    29
    Thanks Everyone!
    I just took the top off and took the disk out.
    Chris
