Making the jump to 7.1? I think
Discussion in 'Archived Threads 2001-2004' started by JoelM, Jan 28, 2003.
  1. JoelM
    JoelM Stunt Coordinator
    Dec 16, 2001
    208
    I have a Denon2802 and it says I can add a rear speaker to my setup. My question is can I add 2 of them? The bad thing about buying speakers is you have to buy in pairs. I have a Panasound 855 running all 5 right now. So my plan would be to run the center and mains off of the panasound and let my Denon do the surrounds. The thing is there's only one set of rear back wire plugs for surrounds. Can it be done or do I need a higher model?
  2. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
    That'll work fine. If the speakers you intend to use are 8 ohm or higher nominal impedance, then wire them in parallel. If their nominal impedance is lower, then wiring them in series might be healthier for your Denon.
