Making Screen Captures with PowerDVD
Discussion in 'Archived Threads 2001-2004' started by Joshua Clinard, Oct 19, 2001.
  1. Joshua Clinard
    Joshua Clinard Screenwriter
    Aug 25, 2000
    1,834
    77
    1,610
    Abilene, TX
    Joshua Clinard
    I just got a new computer with PowerDVD, and I was looking for the option to create screen captures, with no success. I know it is in there somewhere, as I have seen posts on this forum that pointed out this feature. Or maybe they removed it from the most recent version? Can anyone tell me how to do this, or let me know if they have removed this option? If so, is there any place where I can download a version that has this feature?
  2. Scott Dill
    Scott Dill Stunt Coordinator
    Apr 2, 1999
    116
    There is a small icon on the control panel that looks like a camera. This is for screen captures.
    If it is greyed out in yours, perhaps you have the trial version and not the full version
  3. Joshua Clinard
    Aug 25, 2000
    1,834
    77
    1,610
    Abilene, TX
    Joshua Clinard
    Thanks, I will try that. However, I looked all over the Control Panel, and I don't remember seeing it. Although I may have missed it. I got the version that comes with a new Dell computer.
  4. Dan B
    Dan B Screenwriter
    Sep 17, 1999
    1,389
    110
    The default keyboard key should be C, also.
    -Dan
  5. Sean Moon
    Sean Moon Cinematographer
    Jan 25, 2001
    2,041
    The player needs to be set to software decoding before you can capture. I went through the same thing when hardware accelleration was enabled. Switched it off, and then I was able to make grabs
    [​IMG]
  6. JJR512
    JJR512 Supporting Actor
    Dec 11, 1999
    619
    In these first two screen captures (of the monitor display, not of a movie, obviously), I have circled in red the button that takes the movie screenshot. The icon on the button is a camera, as Scott Dill mentioned. The first picture is the default PowerDVD skin; the second picture is an alternate skin, Neo (HiColor), the one that I use.
    [​IMG]
    [​IMG]
    This shot shows that what Sean Moon said is incorrect, at least for me. I have hardware acceleration enabled and am able to make screenshots just fine (some people here already know that [​IMG]). Maybe this setting's affect on the ability to make screenshots varies depending on what video card you use. I have a GeForce2 MX card, for what it's worth.
    [​IMG]
    -Justin "JJR512" Rebbert
    [​IMG]
    Join the JJR512.com [email protected] Team and help cure what ails you. (Click here for more info.)
    Contact me: [email protected] | ICQ: 52675695 | Private Message
  7. AllenD
    AllenD Second Unit
    Feb 20, 2000
    412
    FYI: I have PowerDVD 3.0 and a Radeon DDR in order to listen to DTS. The one and only option for this combo is to have hardware accelerator enabled. I am also able to take captures by pressing C.
