Making M&K S-150 THX system 7.1
Discussion in 'Speakers & Subwoofers' started by John Menoni, Feb 16, 2005.
  1. John Menoni
    John Menoni Stunt Coordinator
    Feb 29, 2004
    220
    I am finally completing my M&K S-150 5.1 system. I love the dipole sourrounds (SS-150s). I do want to upgrade the system to a 7.1 setup. The only problem is that I don't know what to use as the rear direct radiating speakers. Do they have to be 4 ohm speakers like the rest of the system? Can I get away with M&Ks select certified surrounds? Not sure.[​IMG]
  2. TimRP
    TimRP Stunt Coordinator
    Feb 9, 2004
    115
    In a ideal world you would have speakers that match the rest of the system. Meaning two more 150s for the rear two speakers. However with them not being used as much you might be able to get away with the MK selects. And since they use the same tweeter as the 150s, the drop off of not being the same exact speakers won't be as steep.
  3. John Menoni
    Feb 29, 2004
    220
    Thanks Tim. Thats what I was thinking. I'm not that well read as far as the technical aspects of the speakers. I don't know a watt from an Ohm.[​IMG] I was just wondering if it is O.K. to put 8 ohm speakers with a system comprised of 4 ohm speakers. I think my amp will be set to 4 ohm.
  4. TimRP
    Feb 9, 2004
    115
    Just think of ohms this way, the lower the ohms the more stressed the amp will be. Mixing ohms is just fine.
  5. Mark gas
    Mark gas Second Unit
    Mar 23, 2002
    322
    But the 8 ohm speakers will also see less power than the rest of the speakers, the amount will be dependent on amp/reciver used.
  6. John Menoni
    Feb 29, 2004
    220
    Hmmm. Maybe I should try and find 4 ohm speakers.
