Making compilation CD's thru PC - wav?
Discussion in 'Computers' started by Geoff C, Mar 21, 2004.
  1. Geoff C
    Geoff C Agent
    Apr 23, 2003
    42
    I'd like to take my original cd's, and record uncompressed, lossless individual songs onto my HD so I can burn as-perfect-as-possible compilation CD's.
    Is this as simple as using WAV files? Or is there a better way/format of doing this?
    If so, is there software you'd recommend?
    Thanks!
  2. Ari
    Ari Stunt Coordinator
    Aug 3, 1999
    202
    Rip with EAC (Exact Audio Copy) and burn with Nero (use Google to learn how to download the programs). Make sure to use good CD-R media.
  3. Kelvin Tucker
    Kelvin Tucker Stunt Coordinator
    Sep 17, 1999
    59
    I recommend EAC .
    There are lots of opinions on how to best get lossless audio using EAC settings. I must be tone deaf, since I miss the nuances between one setting and the next [​IMG]
    KT
  4. Geoff C
    Geoff C Agent
    Apr 23, 2003
    42
    Thanks, I'll give it a try![​IMG]
  5. JohnVB
    JohnVB Stunt Coordinator
    Aug 16, 2002
    210
    Just FYI, you can use .wav as well. Recored to .wav at 44.1Khz 16 bit stereo. That's what's used on CDs, so you'll have your lossless recording.
    - bones
  6. Christian Behrens
    Christian Behrens Supporting Actor
    Mar 2, 2000
    714
    110
    SF Bay Area
    Christian Behrens
    Er, out of curiosity, what would be another option? I've only used WAV files for this, and he should as well (and not configure EAC to create MP3s).
    Just nitpicking... [​IMG]
    -Christian
  7. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    There are lossless codecs out there. You store them compressed on the hard drive, and play them from there. When you make a CD, you convert the compressed file back into plain uncompressed CD audio. When/if players start supporting lossless codecs (like they've recently started supporting MP3) you can burn them directly.
  8. Jeff Jacobson
    Jeff Jacobson Cinematographer
    Dec 24, 2001
    2,116
    CDex is a good program for extracting audio from CDs. It can also convert the extracted files to other formats.
  9. MikeFR
    MikeFR Supporting Actor
    May 16, 2002
    595
    If you like windows media player 9 there is a converter on microsoft's site that will convert lossless wma's to wav's.
    This allows you to archive your cd's into lossless wma's(much smaller than wav's) and then when you want to make a compilitation you can reconvert them into wav's and burn them.
  10. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Flac - http://flac.sourceforge.net - is another good option for storing ones CDs in a lossless format and it seems to be growing in popularity with the new SlimServer/Squeezebox supporting it as well as some other hardware products. I've tested it out along with the Winamp plugin and it works great. I used EAC to rip and then configured it to use FLAC to do the encoding. It does not get as high a compression ratio as a few other lossless tools but it's fast and more importantly it is really fast on the decoding side. In addition it is open source and portable - i.e. you're not tied to using Windows only.
    cheers,
    --tom
