Fong
- May 12, 2002
...before i start ordering stuff.
getting a 24" x 5' section. will prolly make it ~4' tall (shooting for ~10ft^3)
tempest
ava250
single input cup (binding post)
12ga home depot wire
4" flared port (getting a pair of these)
64oz. of polyfil
and mdf, plywood, glue, and all that other good stuff.
am i good to go? hopefully i didnt leave anything important out...
and i have a few questions to boot:
should i order the stuff for a tempest now, or is the stryke av15 worth the wait (being released on dec. 14 i believe)? if i do preorder the av15, i'll get the stryke 350 amp on preorder too. there is a small price difference between the tempest and stryke if you preorder. preorders end oct.14, so plz try to answer before then.
do i have to use PRs w/ the av15? that will raise the price by quite a bit, and i dont know if i can do that. couldnt a pair of 4" flared ports work? i modeled it in winisp and it looked ok w/ the pair of ports. i used the same enclosure for the tempest i modeled, at 340L. from what i've read, i dont think im pushing it to its limits w/ a 350W power supply, but i like the idea of being able to upgrade later.
is there a difference, performance-wise, between the ava250 and the PE 300-794? if its not significant, then i can just get the PE amp and save some cash.
thanks for any help i get.
tempest
ava250
64oz. of polyfil
