Chris Brock
- Sep 13, 2003
Well today I fired up the twin 1804 IB and was going to start doing some more tweeking with the BFD and when I was playing the low stuff below about 25hz I noticed this horrible noise coming from my IB. So on investigation and a removal of one of the drivers I found this!!!!!!!!!!!!!............
http://bigchris.caraudioplanet.com/problems/
I put some toothpicks in it just to show how much of the surround actually seperated from the basket. It is almost half of the entire cone and some other areas feel fairly weak. I am only running these with around 350wrms per driver and I have only gotten max SPL numbers 1 time. This is an extreme shock to me because in all the crazy things I have done in car and home audio over the past 10 years I have never once damaged or blew a subwoofer. Is there anything I can do to fix this, or will it flat out require a recone? The sub works fine other then this issue. Any insight or suggestions would be greatly appriciated!!
Thanks!!
Chris
Thanks!!
Chris
