chris_everett
- Jul 20, 2003
How can EQ fix a cancellation problem? It can't! If you cut the offending frequency, you have less cancellation, but the same result, areas of lots of bass, and areas of none. Same with an EQ boost. Does this mean that EQ is useless? No, by no means. EQ can fix all sorts of problems, and most systems will benefit from an EQ on the subwoofer channel. Bass frequency response can be smoothed out by EQ, but it can't create something out of nothing.
I don't know why you can't stand bass traps so much Rutgar, but I can assure you that nearly every pro recording studio out there uses them, lots of them, and that they are most certainly not bi-wiring the speakers or buying $1000 power cords, or other such nonsense.
Perhaps you have "active" bass traps, that are designed to absorb only a specific frequency, if so, I can understand your frustration, as these will be very difficult to implement correctly without lots of tools that a typical HT builder does not have.
This is from a FAQ on the Auralex website (a competitor of Ethan's)
Also, I have been involved in pro audio for a number of years before I was interested in HT, and I can assure you that Ethan is a well respected member of the pro-audio community, and has a wealth of knowledge that we can all benefit from. As I recall, he operated his website simply to educate people on building their own bass traps for years before starting his company.
