Samson_S
- Jul 30, 2003
Do you guys thinks I could use an Onkyo receiver with this speaker ? I am thinking about buying the magnepan MMG w and MMG C. Here are the specs of the receiver.
Power Specifications
Power Output* (8 ohm, 20 Hz-20 kHz, FTC) -
Front L/R 65 W/Ch
Center 65 W
Surround L/R 65 W/Ch
Surround Back -
Dynamic Power** -
3 ohm (Front) 160 W/Ch
4 ohm (Front) 125 W/Ch
8 ohm (Front) 85 W/Ch
Amplifier Design
Identical Full-Bandwidth Channels 5
Reduced NFB (Negative Feedback) Design
WRAT (Wide Range Amplifier Technology)
Non-Scaling Configuration -
DACs 96 kHz/24-Bit x 6
High Current Low Impedance Drive
All Discrete Output Stage Amplifiers
Optimum Gain Volume Circuitry
Digital Upsampling
Home Theater Features
THX Surround EX and THX Certified -
Extended Frequency Response (+ 1 dB, - 3 dB) 10 Hz-100 kHz
DTS, DTS-ES Discrete/Matrix 6.1, DTS Neo:6 DTS Only
Dolby Digital, Dolby Pro Logic II
Dolby Digital EX -
A-Form Listening Mode Memory -
Composite and S-Video to Component Video Upconversion -
Composite to S-Video Conversion -
Multichannel Input 5.1
CinemaFILTER
Digital Soundfield Processing Modes 9
Late Night Mode
Color-Coded Speaker Terminals
On-Screen Display -
Adjustable Digital Delay
Crossover Adjustment
Internet Features
Net-Tune -
Ethernet -
Number of Presets (Internet Radio) -
Inputs
Audio and AV Inputs 2/4
HDTV-Ready Component Video Input/Output -
Front-Panel Video Input (with S-Video)
S-Video Compatible Jacks Input/Output 4/2
Digital Inputs 2 Optical, 1 Coaxial
Digital Output -
Amp In -
RS-232 Control Port -
IR In/Out -
Pre Outs
Front L/R, Center -
Surround L/R -
Surround Back -
Subwoofer
Other Features
Dot-Matrix Display
Display Dimmer 3 Levels
Pure Audio Mode -
Dual Banana Plug Compatible Speaker Terminals Except Speaker B
Sleep Timer (90 minutes; 10-min steps)
Phono Input -
Headphone Jack
Zone 2 (Multisource) Line Out -
Powered Zone 2 -
12 Volt Trigger -
A/B Speaker Drive A and B
Front L/R 65 W/Ch
Center 65 W
Surround Back -
Dynamic Power** -
Amplifier Design
Digital Upsampling
Dolby Digital EX -
CinemaFILTER
Late Night Mode
On-Screen Display -
Internet Features
Net-Tune -
Ethernet -
Inputs
Digital Output -
Amp In -
IR In/Out -
Pre Outs
Front L/R, Center -
Surround L/R -
Surround Back -
Subwoofer
Other Features
Dot-Matrix Display
Pure Audio Mode -
Phono Input -
Headphone Jack
Powered Zone 2 -
12 Volt Trigger -
