Magnavox 51MP392H
Discussion in 'Displays' started by BarryNS, Nov 18, 2005.
  1. BarryNS
    BarryNS Stunt Coordinator
    Aug 23, 1999
    91
    I did a search and only found a handful of posts about this budget HDTV set from back in 2004....it's got my eye now due to the recent sale price at FutureShop - $999 CDN, discounted from $1299. With 480p/1080i, other than no HDMI/DVI inputs (component only) any major issues with this set? I'd be using it with a Pioneer progressive scan DVD 578-A, and very shortly thereafer getting a DishNetwork (ExpressVu up here) HDTV satellite receiver.
  2. Tim Jin
    Tim Jin Supporting Actor
    Jan 12, 2003
    529
    Who buys a Magnavox?
    Don't buy it. The shop is trying to get rid of their stock that no one wants.
    No HDMI/DVI is a no go.
    They're not doing you any favors at $999.
    You can get a much better TV with your budget with HDMI.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    $999 Can is pretty low in US$.....
    Hard call on this one...
  4. BarryNS
    Aug 23, 1999
    91
    Basically I was thinking about just getting a 32inch 4:3 CRT flatscreen (non HDTV) to replace my old 27inch Mitsu as a temporary thing till I go bigscreen, but the 32 direct view sets (JVC and Toshiba) with a stand are only about $200 LESS than this Magnavox is selling for now with the sale....
  5. Kirk Patrick
    Kirk Patrick Stunt Coordinator
    Feb 25, 2002
    106
    why not pick up a 30 or 34 16x9 hdtv ?
    sony is too pricey but you can probably buy a toshiba or panasonic which will look just as good for dvd 's and high def
    i bet if you shopped you could find even a 34 for less than a 1000
    also, a and b sound is clearing out toshiba 57 crt's for $1599
    as far as the maganavox, i found several mostly positive reviews as to it's pq so it's probably not a bad set but it doesn't have hdcp dvd or hdmi which means it won't play hi-def dvd
    2 years from now it will be a very large paperweight
    good luck!
  6. Mike Boniferro
    Mike Boniferro Second Unit
    Aug 21, 1999
    273
    Barry, 2 weeks ago Best Buy in Canada was selling this tv for $999 with a Magnavox HTIB... even at that it is a really tough call. (and they've also got it at $999 right now)
    No screen protector on this one (which could be good or bad) and the viewing angles are very poor. I wouldn't buy it just because it's not much more than... they've also got the Toshiba 51 for $1399cdn right now which would be WELL worth the extra $400!
    If that gets too much, got for a 30 or 34" Toshiba CRT.
