Magellan RoadMate 500/700 GPS Review
Discussion in 'Mobile Phones / Entertainment' started by Ronald Epstein, Aug 31, 2004.
  1. Ronald Epstein
    Ronald Epstein Founder
    49,187
    5,980
    9,110
  2. DaveBB
    DaveBB Supporting Actor
    May 24, 1999
    788
    Thanks for the review and pictures Ron.
    How extensive is the database of restaurants, ATMs etc? For example around your house (where you're familiar with everything) how deep are the listings? Everything, half, less than half?
    Does it have Rest Stops as an option? My girlfriend can't go far without knowing where the next gas station or rest stop is on the highway. [​IMG]
    Please report back after a couple of roadtrips. Let us know how good the reception is in a big city with lots of tall buildings around (like Manhattan, downtown Chicago or Philadelphia etc)
  3. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    Will this device learn updated information?
    It's a toy (sorry, TOOL) I'd love to have but I worry that it will age badly.
    Speaking of "love to have", can it be pulled off that stalk to make it less accessable to smash and grab types?
  4. Ronald Epstein
    49,187
    5,980
    9,110
    Henry,
    I will find out the answer to the "upgrade" question.
    That is a GREAT question. Will have an answer for
    you by the end of tomorrow. Waiting for tech support
    to call me back.
    As far as the windshield mount is concerned....
    A simple button at the bottom of the cradle releases
    the head unit from the windshield mount so you can
    hide the unit from would-be thieves.
  5. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I also own a GPS unit although mine is made by Garmin. After my research, I came up with some important issues that every potential buyer should be aware of:
    - There are units meant for road use, wilderness use, & airplane use. The airplane units allow you to track the GPS satellites while at a high rate of speed. The road units allow you to 'follow the road' when traveling to a destination. The wilderness units may _show_ the road but may not be able to calculate directions using the roads. I returned my Garmin Vista (a hiking-only unit) for a multi-capable unit so I could use it on the road.
    - How does the screen look in bright sunlight and dark conditions? Is it washed out or easy to read?
    - How many maps does the unit store? Some road-only units have the memory capacity to store the entire U.S. while others make you upload map segments from CD-ROMs. I wanted a smaller unit so the tradeoff was less memory.
    - Does the unit allow map updates? Most companies will release a new version of software and there will be an upgrade charge. Some road-only units do _not_ have an update capability (which is crucial IMO).
    - Is the antenna sufficient? This is particularly important in cities and near mountains where the signals could be obstructed.
    - Is the unit easy to use while you are driving? You should be able to get all the pertinent info with a quick glance at the unit. A larger screen size allows more info to be displayed. My unit (which has a smaller screen) switches the screens to alert me of upcomming turns or destinations... I don't find this to be a problem.
    - Does the unit come with the maps and mounting kits? This can be a significant added expense.
    FWIW, I have the Garmin GPS60CS which I use for road travel as well as outdoor pursuits. Highly recommended for a multi-purpose unit...
  6. CoreyII
    CoreyII Second Unit
    May 15, 1999
    474
    Hey Ron nice review. From what you've written, it sounds as if there is a one time fee. There is no monthly charge to use the GPS that the unit connects to, is it?
  7. DaveBB
    May 24, 1999
    788
    CoreyII:
    there is no fee. The GPS satellite system were developed for military use but has now found a home in the private sector. Anyone with a GPS receiver can use them with no charge.
    Up until a few years ago the military purposely messed with the signal so that civilian GPS receivers were less accurate. However that has changed. I know two soldiers who were shipped to Iraq and took civilian GPSrs with them.
  8. Ronald Epstein
    49,187
    5,980
    9,110
    I did forget to write something concerning
    the display in bright sunlight. I will add comments
    in the review later today.
    The RoadMate does a very good job of displaying
    a readable image in strong sunlight. It has an
    auto-brightness and auto-contrast feature that
    adjusts to day and night conditions.
    As has already been answered, there is no monthly
    charge to use the GPS unit.
    Though I still have not heard back from tech support
    about updating the road maps, I do see that Magellan
    has software updates available on their website at
    no extra charge. I am uncertain if these are just
    firmware updates or map udates as well.
  9. StephenP
    StephenP Stunt Coordinator
    May 23, 2001
    209
    Ron you are an inspiration to the gadget geek inside me. Thanks for the review, and I'm hoping you get a credit increase on your card for future reviews! Ha ha, congrats on your new toy. [​IMG]
  10. Chris Bardon
    Chris Bardon Cinematographer
    Jul 4, 2000
    2,059
    This sounds like a fantastic tool, but I'm a little worried about its accuracy. I've found that a lot of online maps (mapquest and the like) are a little lacking in accuracy. I've had cases where maps send you down streets that don't exist (anymore, yet, or ever), or the wrong way down one way streets. I wonder, does this happen with this unit's database? What about the extent of maps for rural and residential areas? I'm thinking of times when I've needed to break out maps heading for cottage country, and suspect that this is an area where a gadget like this might be lacking.
    Also, is the unit able to detect a deviation from a planned route and compensate? Say, for example, you're following the provided directions, but hit a detour. Will the magellan be able to detect that you've deviated from its route, and either give you directions to get back to it, or be able to pick up when you rejoin it?
    Last idea (and I really doubt this one), but is the unit able to download data from other sources? I'm thinking of an upgrade where realtime road and traffic conditions can be streamed into the unit to aid in the route planning algorithm.
    Needless to say, I want one now, if for no other reason than to see how it works (and try to make it better!). No wonder I became an Engineer [​IMG]
  11. Craig S
    Craig S Producer
    Mar 4, 2000
    5,788
    235
    9,110
    League City, Texas
    Craig Seanor
    Nice review, Ron. Now you've got me seriously jonesin' for one of these puppies for my road trip out to CA in 2 weeks.
    Chris (& everyone), here's the link to Magellan's RoadMate 700 product page, which answers some of these questions:
    http://www.magellangps.com/en/produc...asp?PRODID=955
    In particular:
  12. Ronald Epstein
    49,187
    5,980
    9,110
    As Craig has answered, yes, the RoadMate immediately
    compensates for any route deviations. On the roads I
    know I don't always follow RoadMate's reccomendation
    so when I make a wrong turn it automatically recalculates
    the route based on the wrong turn.
    Although I have still not heard back from tech
    support I do believe that the maps are upgradeable.
    I just did a rather large FIRMWARE update this morning
    by hooking my RoadMate up to the computer. The display
    now has split-screen guidance that really is a huge
    improvement. There also seems to be more Points of
    Interest added to the maps.
    ....so, yes, I do believe you can constantly download
    new upgrades for this product.
    I don't believe the unit is equipped for real-time
    road conditions. Would be neat if it could do that!
  13. DaveBB
    May 24, 1999
    788
  14. Steven Simon
    Steven Simon Producer
    Sep 14, 1998
    3,276
    7
    Steven Simon
    [​IMG] [​IMG]
  15. Craig S
    Craig S Producer
    Mar 4, 2000
    5,788
    235
    9,110
    League City, Texas
    Craig Seanor
    On the map updates question, I found this information in a review at ZDNet:
    Seems a little odd that they would be using Compact Flash instead of the USB port on the unit, but this review was from January, so they may have been looking at an older version of the unit. Hopefully Ron will find out more about this from their tech support - there doesn't seem to be anything on their web site.
    FWIW, I did some quick online price shopping, and found the RoadMate 700 for about $1050 at both tigergps.com and cartoys.com.
  16. Ronald Epstein
    49,187
    5,980
    9,110
    Dave,
    I'll get back to you on how extensive the list of
    restaurants and other stuff is.
    My guess is not extremely extensive.
    The RoadMate had problems locating BJs Warehouse
    under Grocery Store. This was before I did the new
    firmware upgrade so perhaps it is in there now.
    Give me some time to play with this a little more
    and I promise to get back to you on that question.
  17. Roger Mathus
    Roger Mathus Supporting Actor
    Sep 1, 1997
    549
    110
    Central Oregon
    Roger Mathus
    This unit has been on my gadget want list since it was introduced. On the question of brightness......do you think
    it would work in open top car with top down? I would be using in 2004 BMW Z4 roadster.
  18. Craig S
    Craig S Producer
    Mar 4, 2000
    5,788
    235
    9,110
    League City, Texas
    Craig Seanor
    Ron, how long is the windshield mounting arm?? I have one of those really deep windshields. Smaller folks could probably stretch out on my dash and take a nap... [​IMG]
  19. Ronald Epstein
    49,187
    5,980
    9,110
    Craig,
    Here is a picture of the windshield mount that
    is included:
    http://www.magellangps.com/en/store/...asp?PRODID=965
    Typing from memory, it seems to have a rather lengthy
    extension. In my car (a Mercury Cougar) it actually
    sticks out past the dash.
    Roger,
    I am going to a party tomorrow. I'll ride with
    the sunroof open so I can see how sunlight affects
    the display. I'll get back to you.
  20. CoreyII
    CoreyII Second Unit
    May 15, 1999
    474
    Hey Dave BB thanks for the reply. [​IMG]
