Maelstrom dimensions needed (1 Viewer)
JohnA
Can someone post the following for a Maelstrom driver?
1. Bolt circle dimension
2. Mounting screw hole diamter
3. Outside diameter of the mounting flange.
The bolt circle diameter is the diametric dimension that the eight mounting screw holes are located on. This can be measured going from the center of one mounting hole to the center of another directly across from each other (or 180° from each other)
-JohnA
neonpizza
