Jason Co
- May 24, 2002
Well I finally took the plunge and got into separates. I just bought a Parasound 1500 2 channel amp from a fellow HTFer. I guess I didn't really know what to expect when I got this but it was quite an adventure. Got home from work last night and found a huge box in my living room. IT was very professionally packaged and I believe it set some sort of record for peanuts in that size box. I opened it trying to be overly conscious of not dumping peanuts everywhere. That idea didn't last long once my 10 month old son and 4 year old daughter actually got in the box and went to town. Oh well they were having fun so that was all that mattered. I wasn't sure if I wanted to put the amp in my entertainment center due to the ventilation issue. Well that issue was solved for me seeing it didn't fit anyway. No big deal I just put it on the floor behind one of my mains. Finally got everything hooked up and noticed a nice buzzing noise coming from my mains. Needless to say I was slightly pissed! I went to the old HTF and looked it up and discovered it was my cable outlet. If I unplugged my cable all was good. The only thing that I found that can fix the problem is Link Removed I was wondering if anyone found anything from Rat Shack that I could pick up that would do the same thing.
Anyway, to make a long story longer I started off with The Patriot and the difference wasn't as immediate as I had expected. I did notice the sound field seemed a bit wider and the sounds were more crisp. I figured maybe 2 channel music would give me a little bit better result. I threw in Uncle Kracker and was quite impressed with the liveliness and purity of the acoustics. NOW that was what I was waiting for! I had a mix of Diana Krall that I figured would be the bomb with this new amp. I asked my wife to put the disk in. Once she put it in my Panny 5 dvd changer a horrible noise came from my dvd player. Monsters Inc. was in one of the other slots and somehow came loose as the tray closed. I immediately shut it off and realized the friggin disk had popped out of the tray and was now stuck in my dvd player. Needless to say I was pissed. I spent the next half hour shaking the damn dvd player until it burped up my now ruined disk. I hooked the dvd player back up and thankfully it still worked. The Diana Krall disk almost brought a tear to my eye. It was fantastic.
After cleaning up the peanuts, I decided I would throw in the new LOTR extended version. Talk about audio bliss!!!! I literally thought I was in the forest with Frodo. Birds were chirping, crickets surrounded my...it was unreal. To conclude this diatribe I am absolutely ecstatic with my new purchase.
If anyone know how to cure the buzz problem, please let me know. The last question I have, is it okay to leave my amp on all the time in stand by mode or should I shut it off manually while it's not in use? Thanks again to the HTF for making me spend more money!!!! J/K I thank everyone (especially Yogi) for the guidance in this matter.
Jason
Jason
