oharag
Grip
- Mar 24, 1999
I went to Circuitcity and purchased the following:
Panasonic PT53TW53 $1,549.00 plus a $250 mail in rebate plus a $100 gift card!
Onkyo HTS760 HTIB $449.99 (10% off with TV purchase) plus $50 rebate plus $50 gift card!
For the price I couldn't beat this offer. On top of this I got 12 month no interest! The only thing I do not like on this set is the size. Much bigger than the Pan PT53WX53 set. Though this set goes for $1,699. So in the end I saved $400.
I purchased the 4-year in home service plan as well for $399.
Here's a couple of questions:
- Would you guys recommend buying the service plan for a large set like this? I just keep hearing to pass up on the service plans. If an electronic device were going to fail it will most likely fail in the first year and be covered under the manufacturers warranty.
- Where should I go and purchase 12 gauge speaker wire? I remember people on this forum stating to go to HomeDepot and purchase 12 Gauge wire. Is this the best cheapest wire around? Also, the speakers I'm getting are cheap
I believe the fronts have binding posts, but all other speakers have spring clips. Does the bare 12 gauge wire fit into these clips? The speaker wire that comes with the HTIB are of a smaller gauge.
- I want to buy speaker stands for my speakers. Can anyone recommend a good speaker stand? The speakers are minis (though fairly large for a HTIB). Circuitcity had a fairly nice speaker stand. It had a base that clamped onto the bottom of each speaker. It was also height adjustable. the only thing I didn't like was the flimsiness of the stand. It wobbled if you put side force on the speaker.
- At this moment I did not purchase a DVD player. I'll use the gift cards to do this. Eventually I want to purchase a progressive scan output DVD player. Should I get one with component outputs, or is SVHS output fine?
- I have Comcast cable. I got a special deal on a Starz package. It came with a digital settop box - basic, standard and Starz. I asked the salesman whether it could output HDTV, and he said no problem. The installer didn't know whether this was the case. He called a dispatch that said I could receive HDTV signals with the right connector. I read the settop box manual, and it states that I need to use component cables out of the settop box to the TV in order to receive HD signals, but it says something about getting an HD box from Comcast! What's the deal here? Can I receive HD programming from a digital settop box from Comcast? A friend of mine who has Comcast states that it costs him $5 extra a month to get HD programming from Comcast. Comcast Sports Network has their sports programming in HD. Would it come through as HD if I used component cables?
Sorry for the ramblings. So much to learn. Thanks guys/gals.
oharag
oharag
