James Buhler
- Nov 18, 2000
Hi,
I am having a problem setting up a macro on the remote for this reciever. I can get a macro set up to turn on the amp, then the TV then the DVD player but cannnot get the amp to switch from whatever source it happens to be set at to DVD.
I have already set up the remote with the correct input codes for my TV toshiba 65hx83) and DVD player (Pio DV-563a). I also programmed a learned button for the "picture size" function on the Toshiba TV.
What I would really like to do is set up a macro to do the following:
1.Turn on amp
2.switch amp to DVD source
3.Turn on TV
4.Set pic size on TV to "full"
5.Turn on DVD player and have the remote remain on DVD source so that once all components are on, the remote will control the DVD player functions.
Any help that anyone can provide would be most appreciated.
James
1.Turn on amp
3.Turn on TV
James
