1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
MA500 Remote turnons
Discussion in 'Archived Threads 2001-2004' started by John Tuttle, Jul 30, 2002.
  1. John Tuttle
    John Tuttle Agent
    Aug 8, 2001
    26
    I have two MA500s and cannot get them to go into standby mode. I am running an SR-7200 and a MM-9000. How do I setup the triggers to make the MA500 go into standby? I tried both settings (1 and 2) on the MA 500s and it did nothing.
    Any helpful suggestions?
  2. John Tuttle
    John Tuttle Agent
    Aug 8, 2001
    26
  3. VerhartR
    VerhartR Auditioning
    May 29, 2002
    John,
    I own five MA6100's, which are comparable to the MA500. There are two inputs: one remote input (orange) and one video input (yellow).
    Connect your SR7200 remote out to the MA500 remote in. Both connections are orange. When you now switch off your receiver using the remote control your MA500 will switch off also. This will NOT work when you switch off your receiver using the power button on your receiver.
    You can also connect one of your video monitor outputs from the receiver with the video input on the MA500. The MA500 will swich on as soon as it receives a video signal. When the video signal stops the MA500 will turn of automatically after 10 seconds.
    Richard Verhart
    The Netherlands
  4. John Tuttle
    John Tuttle Agent
    Aug 8, 2001
    26
    Thank you very much. I will try that tonight.
  5. Mark_Buss
    Mark_Buss Extra
    Jan 13, 2002
    15
    I too have 4 MA6100's and an MA700 running from a Marantz SR7000 and it works great. Need 5 rca cables, start from the remote out on the amp (check the instruction guide if any doubt where this is) and then run the wire into and out of each MA500 remote RCA jack. Turn the SR7000 off when you try this, then turn it on and they should all click on.
    mark
  6. Chuck Paskovics
    Chuck Paskovics Stunt Coordinator
    Feb 26, 2002
    98
    Can anyone tell me if this will work with other receivers? I'm using a pioneer vsx-36tx. If I connect one of my monitor out's to the amps will it put it into standby? What should the selector switch setting be? 1 or 2?
  7. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    "Can anyone tell me if this will work with other receivers? I'm using a pioneer vsx-36tx."
    No. The MA-500 can only be triggerred by another Marantz component with the "Remote Control (RC-5)" proprietary system. The MA-6100, which is similar in specs to the MA-500, can also accept a video or 5-13V signal as a trigger.
    "You can also connect one of your video monitor outputs from the receiver with the video input on the MA500."
    No you can't, unless there is a different version of the MA-500 outside of the US. The version sold in the US can only accept the Marantz proprietary (RC-5) trigger.
    Also be aware when first setting this up that the MA-500's power switch on the front panel needs to be in the "ON" position. When you first turn on the "triggerring" component (receiver, processor, etc.), nothing will change (the MA-500s will still be on). Once you turn the receiver's power off, the MA-500 will then go into standby mode.
    Michael
  8. Cameron Wright
    Cameron Wright Stunt Coordinator
    Dec 23, 1999
    143
    is that what the hell you use the Remote jack for???
    *Ding*
    [​IMG]
