M&K vs. Monitor Audio--which one to get??
Discussion in 'Archived Threads 2001-2004' started by Scott Stephens, Jan 23, 2002.
  1. Scott Stephens
    Scott Stephens Stunt Coordinator
    Dec 23, 1999
    130
    I've been looking at upgrading my speaker system and have a dilemma: I can't decide between M&K and Monitor Audio. Anyone out there have any suggestions on overall sound quality/value?
  2. JonnyD
    JonnyD Auditioning
    Jan 22, 2002
    6
    Scott,
    I have a friend in the UK who uses nothing but M&K THX certified speakers and I have heard the set up and it is really rather good. I know what he paid for them... very expensive I would go with the ones that sound the best to you. I have a Monitor center speaker and I would recommend it to anyone. crisp and clean sound very capable and looks good with the grille off.
    JonnyD
  3. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    My impression was that Monitor and M&K are distinctly different in their sound characteristics. Spend some time with both before deciding.
  4. Brian Corr
    Brian Corr Supporting Actor
    May 10, 1999
    535
    I own the M&K 150's and work for a dealer for Monitor Audio.
    If music is important to you, then I would recommend Monitor. The silver 5i's continue to blow me away at how good they sound for the price. And the gold 20's, well, there awesome.
    Now, I like my 150's for music! But I'm not an audiophile and don't put the main emphasis on music.
    You can't beat M&K for a pure home theater set-up, although they are expensive.
    I don't think you can go wrong with either, but they both sound different. Listen and see if one grabs your ear over the other.
  5. Jeff Adams
    Jeff Adams Screenwriter
    Dec 13, 1999
    1,549
    I have heard both speakers. And I like them both. It really depends on what you use your system for. I know for home theater, M&K's are hard to beat. I have never heard Monitor Audio's for home theater but about 2 weeks ago I demo'd the 20's and the 60's for strait stereo playback for music and wow. I was completely blown away and amazed. If I could have a dedicated 2 channel room for music only, Monitor audio would be my choice.
