M&K THX-750 set
Discussion in 'Archived Threads 2001-2004' started by Greg Kolinski, Oct 16, 2002.
  1. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    I currently have the center speaker ,and I am seriously thinking about getting the rest of the setup.I have an Onkyo TXSR-600 reciever.The listening room is appprox 20X12
    .Do I have enough reciever to properly run this set?? I noticed that the front speakers are 4 ohm and the rears are 8.Since this is a nice reciever ,but not real high end,want to make sure I have enough to run the speakers properly.
    thanks
    Greg Kolinski
  2. Greg Kolinski
    Oct 13, 2002
    331
    Is my question that stupid???/ Or did I offend everyone already??? [​IMG] I am usually just a thread killer.[​IMG] Did go and talk to the guys at the audio shop,and they said I should be OK with the mid range Onkyo.
  3. James Stierman
    James Stierman Stunt Coordinator
    Jul 21, 2002
    88
    The Onkyo should be ok to drive those speakers, you should very impressed with quality you will get.
  4. Al_Swanson
    Al_Swanson Agent
    Aug 17, 2001
    39
    I talked to Onkyo before I bought my 750 setup and they stated that I should NOT use their systems as they don't support 4 ohm. It was one of the main reasons I moved to my Denon. Now, Denon doesn't explicitly state that they support 4ohm, either. But when I talked to them (and M&K) they were very positive in their claims that I would have no issues with the 4ohm.
    They were right!
  5. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    Greg, I run an old Yamaha 2092 receiver with 4 ohm M&K S85s all the way around, and have absolutely no problems. The Yamaha has a 4 ohm/8 ohm selector switch on the rear panel though.
  6. Greg Kolinski
    Oct 13, 2002
    331
    I am already running a 750 center channel,with no problems yet.Would adding the other 2 fronts ,as the rears are 8's,be ok,I would think.What did Onkyo say for the reason not to use the low ohm speakers?
  7. Al_Swanson
    Al_Swanson Agent
    Aug 17, 2001
    39
    I looked for the original email from them - but cause my company has a ridiculously restrictive email retention policy, it's long gone. Basically, they don't support low-impendence speakers and they would run the receiver too hard. I am sure others will disagree about why not to do it, I am just relaying what Onkyo told me.
  8. Greg Kolinski
    Oct 13, 2002
    331
    I dug out the spec sheet for the AR 510's im running in front now,they are 4 ohm speakers,have had them since 91 or so.Have used 2 JVC recievers and the Onkyo with them .If they havent hurt anything I guess the M&K's wont?
