M & K 150THX question
Discussion in 'Archived Threads 2001-2004' started by JohnDW, Aug 25, 2002.
  1. JohnDW
    JohnDW Agent
    Aug 19, 2002
    40
    I am about to put them in a 22x18 room with the rear open to the rec room - someone suggested these speakers are "monitors" in that they need a totally enclosed room or won't sound right - any thoughts ? Anypne with experience putting them in an irregular shape and/or open and /or large room ?
    thanks
    JDW
  2. Rob Rodier
    Rob Rodier Supporting Actor
    Jul 11, 2002
    538
    They are designed to be used with the m&k subs (IMO the best)while your situation might not be ideal, I don't think that you will run into any unique problems by using them. The best way is to try them and see.
    -rob
  3. jason celaya
    jason celaya Stunt Coordinator
    Jul 1, 2001
    143
    and THX processor
  4. Paul_Saul
    Paul_Saul Stunt Coordinator
    Nov 6, 2001
    115
    They will be fine. They work great.
