Lutron Spacer Installation (1 Viewer)
Jay Mitchosky
Just picked up my Spacer components. Reading the installation manual for the remote control master it indicates a box depth of minimum 3 1/2". Mine is not. Total depth from edge of wall to pack of box is 3 1/4". Will this be a problem or should I plan to remove the old box and install a deeper one?
Shawn Keeler
I am using the same size box, and the Lutron Spacer. I haven't had a problem so far. I think they give those recomendations because of the heat the Spacer generates while on, but I don't think you will have a problem.
atlanticshores
