Lutron Dimmers
Discussion in 'Home Theater Projects' started by corona13, Aug 28, 2006.
  1. corona13
    corona13 Stunt Coordinator
    Aug 5, 2006
    105
    10
    When mounted multipule Lutron Remote Dimmers next to each other, do you have to be concerned about the remotes interfering with the other switch?
  2. Adam Gregorich
    Nov 20, 1999
    15,841
    729
    9,110
    The Other Washington
    Adam
    Are you talking about "IR" Lutron remotes like the spacer, or their hardwired remote switches? If it's the hardwired ones, then no, if they are wired correctly. You will want to read the manual to verify if they are derated when ganged together like their regular dimmers are.
  3. corona13
    Aug 5, 2006
    105
    10
    I have what is called Maestro?
    It will be hard wired.
  4. Adam Gregorich
    Nov 20, 1999
    15,841
    729
    9,110
    Adam
    It shouldn't be a problem to have them next to each other. Like I mentioned earlier, you will want to read the manual to verify if they are derated when ganged together like their non-remote dimmers are.
