LT150 and RP 91 settings??
Discussion in 'Archived Threads 2001-2004' started by Ari, Oct 11, 2001.
  1. Ari
    Ari Stunt Coordinator
    Aug 3, 1999
    202
    I just got my LT150 yesterday and will be pairing it with a Panny RP91 on a DaLite 100" 4:3 Matte White screen.
    I'm currently having some renovations done on my HT and won't be able to hook up the system for a few days...and hence won't be really able to give my new PJ a workout. I was wondering if any of you have used this combination before and what settings (both RP91 and LT150) you used...
    I tried the LT150 out of the box last night projecting an image on wallpaper and so far, I love it!!
  2. Lou Sytsma
    Lou Sytsma Producer
    Nov 1, 1998
    5,939
    407
    9,110
    Lou Sytsma
    Hi Ari.
    I have pretty well the same combo as you but am using the Dalite Hi-Power 60 x 80 screen.
    Settings used on the RP91 are as follows:
    Picture settings - in progressive mode:
    - the 'U' settings
    - High Sharpness - +1
    - Gamma - +1
    - Mosquito Noise - -1
    - Video Transfer Mode - Auto2
    For the LT150 - set Gamma to Natural1 - I then change the Gamma setting on the RP91 if need be.
    Turn off the white segment ie remove the check mark
    This works pretty well. I find changing options on the projector clumsy whereas the RP91 is much easier.
    This is a great combo and I am very happy with it.
    Good luck and enjoy!
    Every man is my superior, in that I may learn from him.
    MyHTSetup
