Lsi 15 or Lsi 25?????
Discussion in 'Archived Threads 2001-2004' started by AhsanR, Jan 18, 2003.
  1. AhsanR
    AhsanR Stunt Coordinator
    Jan 18, 2003
    207
    Hey guys,
    First time post here, well the other week I listened to some Polk Lsi's, and was glad to say I was amazed. The store was selling a 5.1 set with the Lsi15's and LsiFx rears for 3200, which I thought was a fair deal, until I came online to www.acousticsounddesign.com !!!!!
    Now then, my budget is $3500 for speakers, give or take the $500. I'm worried IF I should get a Lsi15 7.1 set, with 4 Lsi 15's and two dipole FX's, or a 5.1 LSi25 set with 2 Lsi25's with two dipole FX's?
    What type of power should I run these babies under? Is 7.1 that big of a deal?
    I have not had a chance to hear the Lsi25 but whats the difference from the Lsi15? If I purchase a seperate subwoofer (SVS likely [​IMG] ) will it matter which speaker has the better subwoofer?
    And one last question, how do you think the Polks stack up against the Axioms, thanks in advance. I'm on a tight tight tight tight budget.
  2. BrianSmith
    BrianSmith Stunt Coordinator
    Jan 8, 2003
    58
    Want to save more money?
    Try out www.rocketloudspeakers.com They use the same tweeter as the Polks, cost less, look better, and sound great (according to others).
    I have a pair on order.
    -Brian
  3. AhsanR
    Jan 18, 2003
    207
    Thing is brah, I haven't heard the Rocekts...... and on AVS, someone had mentioned that the Polk Lsi series had outperformed the Rockets in HT.
  4. AhsanR
    Jan 18, 2003
    207
    Personally, if someone has done an A/B test on the Polks V Rockets, that would be very interesting. They book do have very similar characteristics.
  5. AhsanR
    Jan 18, 2003
    207
    BTW, the Rocket set if I added tax in does cost more than the Polks, but I haven't ruled out the Rockets completely, I am just trying to play the game safe here.
    What do you guys who own the Rockets think? Do they sound similar to Lsi's? How's the Bass extension?
  6. Jan H
    Jan H Cinematographer
    Nov 6, 2001
    2,007
    I got my Polk LSi setup (25's, C, FX,) from Acoustic Sound Design and couldn't be happier. For about $2600 you simply cannot do better in a speaker package. I've heard the 15's are great too.
  7. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    AhsanR,
    I have the Lsi's and recommend them to everyone, For MY money and MY ears they are the best choice. No I've never heard the Rockets, so I cannot offer an opinion on them. Here's a link you might find interesting. http://www.onhifi.com/product.shtml
    As for setting up a 7.1 system, it is definetly worth it. There are a lot of people that will tell you that there are no movies with a 7.1 soundtrack, which is true. But, there are some DD-ES and DTS-EX titles out and there are sur to be more in the future. Most if not all &.1 receivers/pre-amps can offer up a great matrixed rear sound using various surround modes (Neo, Logic 7, DSP modes, etc.) I say go for it!
  8. BrianSmith
    Jan 8, 2003
    58
    Any Rocket owners want to chime in? Surely someone has compared the Polks and Rockets?
    -Brian
  9. SkiingNinja
    SkiingNinja Second Unit
    Aug 14, 2001
    311
  10. Don Black
    Don Black Screenwriter
    Dec 11, 1998
    1,480
    Acoustic Sound Design only warranties the Polks through them. The factory warranty doesn't apply. =(
  11. bruin
    bruin Second Unit
    Nov 29, 2002
    264
    Can someone who owns a Polk Lsi speaker try replacing the tweeter with the VIFA 1" XT? The tweeters used by the Lsi's and Rockets look the same, I wonder if it sounds the same too. OR, if LSi and Rocket users can open up their speakers and check if there is a sticker...
    If they do use the VIFA XT tweeter then...i'm just really curious as to how some speakers end up costing more. The parts including the x-over, which can be bought and made, are really the differences IMO. But the application may be different.
    So if any of you LSi or Rocket users check out your tweeters' brand or try putting in a VIFA XT tweeter for kicks please post your conclusions
  12. SkiingNinja
    Aug 14, 2001
    311
    FYI - The tweeter in the Rockets is the Vifa XT25TG-30. I can take a picture of it if you like [​IMG]
