dan scorpio
- Jan 19, 2003
do you know where i can get a low pass flter for bass shakers to connect to a receiver?? in toronto?
BTW John, I see you got the Halo pre/pro, is it as sweet as the hype? How is that B&K amp holding up compared to those Parasounds you let go? Why not the matching B&K pre/pro?Derrick,
I had used a Parasound AVC-2500 for a couple of years and sold it as it was becoming sound format outdated. I installed a Pioneer VSX-49TX as a pre/pro while waiting for the HALO controllers to make their debut.
I did audition a B&K Reference 50 in my system when I installed the Reference 200.7
It quickly went back as it suffered from a high pitched processor whine.
I have been using the C2 in my system for about a month now. I am vey pleased with the piece. I use the 2 programmable channels on my TT arrangement. One is used to feed my subharmoic processors. I use these on the TT's signal for bass effect lacking movies. The other channel feeds the TT's power amp directly and bypasses the processors completely. This way I have the option of using a processed signal, unprocessed signal or both. Each programmable channel has independant level and delay settings as well as crossover selection.
The C2 has a preout dedicated for TT use with a 20Hz lowpass filter implemented on the signal but it's delay and level settings are controled by the Main sub channel. I wanted complete independent control.
As for your equalization and active filter questions.
The Auras have a hugh hump at 45 hz. An EQ could be used to tame this. A Paradigm X-30 active crossover is a good choice if you would like a variable unit.
