Scott McAllister
- Oct 30, 2002
I just moved into a new apartment and finally have my home theater set up and running. Unfortunately, due to the design of my living room, I am forced to put my HT system in a small cubby and catty-corner everything. If you need imagery, picture yourself flat against your fall facing out. Turn your head to the right and pretend that your setup in in the corner.
Since I've set things up this way, I have noticed a severe drop in sound fidelity from both music and movies. Especially noticable, is my tweeter range (i.e. cymbol crashes, hi-hat taps, etc.), and my bass, even though my sub is in a corner. Spoken dialoge from my center channel is also noticably less clear. The room was designed to be set up like this, but I'm extremely tempted to move everything around and put the system up against the long wall where my couch is now. Are there suggestions as to why this. Is this entirely due to speaker positioning or could it also be the room itself?
Scott
Scott
