Loss of digital surround sound
Discussion in 'AV Receivers' started by Steve_SAL, Jun 26, 2004.
  1. Steve_SAL
    Steve_SAL Auditioning
    Jun 22, 2004
    2
    Hello, Everyone. This is my first post. What an amazing site.
    I've got a problem getting digital surround from both my DVR and DVD player. I've got a Harmon Kardon AVR 520 receiver that has two optical line inputs in the rear and one in the front of the receiver. I can plug the optical line from the DVD into Optical In 1 and get perfect sound in the DVD mode of the receiver. I can plug the DVR into the same line and get perfect sound as well in the same DVD mode. The problem is I can't get digital sound when I have both pluged in to the two optical lines. I've tried switching them and running them through the Video 1 mode. I guessed maybe the 2nd line was bad but the front line isn't getting me the sourround as well.
    Any suggestions?
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Welcome aboard, Steve. I think you'll get a better response here in the Receivers/Amps section.
    Are you saying that you don't get any digital surround at all when both optical lines are being used — and that if you disconnect either one of them then the surround processing returns?
    Does the receiver have a coaxial output as well?
  3. Steve_SAL
    Jun 22, 2004
    2
    Jack,
    That is correct. I don't get any digital sound if I'm plugged into both lines. Neither the VDP or the DVD mode will provide a digital signal. I do have a coaxial, which I probably should try. I just wondered if anyone has encountered this problem before.
  4. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Are the digital inputs assignable? Assign each to a different input, and all should be fine. Most receivers do not automatically recognize the inputs as assigned to a particular source.
