Looking to upgrade my current speakers. Please Help
Discussion in 'Speakers & Subwoofers' started by tonyKwok, Apr 14, 2005.
  1. tonyKwok
    tonyKwok Stunt Coordinator
    Mar 2, 2005
    93
    hi everyone,
    I am looking to buy a set of new front speakers along w/ a new center channel. My budget is to stay below $500. I will be running these w/ 2 AR bookshelf surrounds + 10" Dayton sub on a Denon 1905. Can you guys help me out with some suggestions?
    thanks
    tony
  2. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    IMO you should get the same AR brand/series CENTER for a matching sounds. You don't want to have a center that is so bright that completely covered up the 2 mains or other way around.
  3. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    Tony,
    Have you checked out my thread about LCR under 400. That may help you get started on your search because I have received some very, very helpful information that may help you as well.
