Looking to get new equipment (1 Viewer)
JWPrendergast
Jason Prendergast
What are you looking for (Speakers, Subwoofer or Both)? front, center and ceiling speakers, possibly subwoofer
Primary Use: 10% Music, 90% TV & Movies
Desired Configuration: Dolby Atmos
Room Size: 19'x19'
Is the room open to other areas of your home: yes
Do you already have an AV receiver or amplifier? looking to replace
What's your budget (low to high): depends on value, no real set budget
Any special requirements (Wife Acceptance)? Nope
My 10 year old HK AVR 354 is on its way out, which is as good a time as any to upgrade the sound system. We have a 5.1 setup now (1 of the rear surrounds might be blown). We watch movies and tv for the most part, and would like a setup that is geared for this. We havent set a budget yet, but would like to keep it below $5000. Receiver needs to have a zone 2 for our patio speakers as well as dobly atmos. Havent had to look for this equipment in a long time, and know a lot has changed. TV is 4k with HDR, if that matters.
ArmSC
Coastal SC
Tony
Hey Jason Welcome to the forum :welcome:
Lets see if we can get this going.
I have some questions for you.
  1. Are you looking for all ceiling speakers or just the Atmos ones?
  2. Are you wanting to replace all 5 current speakers?
  3. What format are you looking for the main zone 5.1.2?
  4. You say possibly a sub are you keeping the one you have? Are you happy with it?
  5. How loud do you like it?
  6. Are you looking for towers, books or satellite speakers for the non ceiling options?
  7. If you're not going towers do you plan on wall mounting?
TheThrillisgone
