Looking into an SVS
Discussion in 'Speakers' started by MichaelPR, Dec 21, 2003.
  1. MichaelPR
    MichaelPR Second Unit
    Nov 16, 2003
    401
    Looking to pick up one of the powered SVS's between $500-$600 for an after christmas present based on all the information I've gathered on this forum. Just out of curiousity though when i hook my sub up to my reciever it requires just one subwoofer cable. When I look at the pictures of the BASH amp on the SVS I dont see this input I just see a left and right input? How would I go about hooking this up to my receiver? as i believe my reciever only has one subwoofer hookup. can anyone clarify or do i make no sense? Also what SVS do you recomend in that price range?
  2. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    The SVS has both L and R low level inputs. You can select either one; it doesn't matter.
    If you are using the bass management circuit in your AVR (recommended), just set the SVS filter control switch to "Disable" and plug the sub cable into either the L or R jack.
